  • Download and install one of our product
  • Complete the product registration process
  • Use the account credentials created during activation to access the forum.
Sign up
Mick
When making outgoing calls they are limited to 4 minutes in length.
I am struggling to work out there this restriction is being set.
Twilio have a 4 hour call limit, so it does not appear to be there in Twilio settings
I can see an error in the twilio logs:
32015: Call is terminated due to exceeding maximum call duration
Which is initialted either by a Twilio limit or set at time of call.
Twilio suggest that the limit is set in the request parameter - which i can see is...
timeLimit=\"240\"
Where do I change this?? It is super frustrating
Avatar
Discard
Max
Hi Mick!
We introduced recently a System Parameter (ir.config_parameter) connect.call_duration_limit, but it's not set by default :) So I am surprised that you have it.
I really have no idea.
Actually, I have an idea :))
Create a system parameter connect.call_duration_limit and set it to 3600 for example...
Mick
Author
OK created system param. Creating the override has allowed it to work correctly.
Disappointingly setting it to 0 does not override it :(
